Celsius Gauge Conversion
Knowing that 100C = 212F, use this as your basis, and keep in mind that a 5 degree change on the C gauge equates to a 9 degree change in F (From the conversion formula F = 1.8C + 32; 1.8 x 5 = 9)
Hence:
85C = 185F
90C = 194F
95C = 203F
100C = 212F
105C = 221F
110C = 230F
Note that the high and low values of the range above are easy numbers to equate and remember for both scales (85=185; 110=230). You could print this out and tape it to your dash, but I imagine you will be ‘thinking in Celsius' quite easily once you find your comfort zone of operation there.
Hope this helps. - Jody
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
