Old 07-22-2010, 08:59 AM
ERA Chas ERA Chas is offline
See comments in bold below:
Originally Posted by Ronbo View Post
I run it in my street vehicle, plan to run it in the Kirkham as well. So you're encouraging a guy to use something in a Cobra that you haven't used in a Cobra? Nice. Your street vehicle and a Cobra are worlds apart from a heat production/retention standpoint.
The problems you mention were in what? Engines running water because your combustion chamber temps were too high from the steam pockets. Your combustion chamber temps will decrease with the waterless (and remain more stable to boot). I never had ANY problems with chambers /steam or ANY coolant-related issues in 15 years with the same block and system in a Cobra. Iron block, aluminum heads, aluminum rad. Using green/distilled water mix changed biennially. Where do you get this stuff?
As far as damage, thread after thread of anodes, corroded radiators, coolant leaks, ate up aluminum, yada, yada. (leaks, leaks, leaks) If you could produce these reams of evidence, they will be found to be caused by negligent cooling maintenance, not using the block drains and or aged equipment.
As far as internet searches of problems with Evens? Found lots of boil-over conditions solved and one guy that didn't know if he should top off his leaking coolant system with water.
Sorry, not seeing the problem here. Other than convincing yourself it won't work because the herd runs water. (I saw one reply here from someone actually using it that said it helped, everyone else seems convinced it won't based on their experience not using it) Missed my point entirely while doing your Evans commercial. I've used the water method exclusively because I learned the proper way to install and care for it which eliminates ANY engine/radiator corrosion issues or the mysterious combustion chamber volcanoes you imagine. No anodes or yada-yadas. Thus, no reason to look for a"BETTER WAY"-especially a more costly better way.
But the major point is that your response does nothing to help Undy solve his question. He doesn't NEED a better coolant. Whether using water, Evans or Kool-Aid---what is causing coolant to find oil and gel in his valve covers???
Chas.
