Old 07-23-2010, 10:51 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
OK--watched your tape of the dyno run----
Couple of questions---I only saw one shift so I assume that it was just above an idle in 4th gear???
Does this do it on ordinary street driving????
Your set up will not take a wot at an idle in high gear---not enough timing, not enough fuel and it recovers by 3000rpm and runs----
You can't just jump on the throttle from idle in high gear tied down on a dyno with a stick shift car. an auto trans has a t/c vs your clutch--
Nothing wrong with car, just improper dyno operation
