Old 07-27-2010, 08:36 AM
mickmate's Avatar
mickmate mickmate is offline
The parts are being made to adapt to any frame with the Jag rear end in it. If you look at the chassis mounts they are simply threaded sleeves and gussets for bracing forward/rear. They could be reversed to mount higher at front and lower at rear and they could be easily made shorter or longer to fit about any application. I have looked at the billet hubs but I don't make parts like that in house hence a good price hike plus the additional expense and hassle of changing over and shimming your bearings and hubs to new carriers. The other goal for these was to be a simple retrofit most guys could do in their own shop. I will have the parts available shortly and will be keen to work with guys like the Arntz/Butler and Unique owners so they will fit them also.
mickmate
http://www.actoncustom.com/
