Old 07-29-2010, 09:59 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I think you may get away with a new set of bearings and turning your crank if you're lucky. Should be under $500.00 if you pull the engine yourself. Rick Lake one of your neighbors in East Brunswick, New Jersey has always been a good source to go to for technical info on these engines. Rick could at least refer you to his machine shop which is a lot closer than PE.
Clois
"Let's roll"
"Be part of Something Good
