Old 07-29-2010, 10:00 AM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally Posted by bermblaster41 View Post
yes it is a steel billet cam... Last year I lost 2 lobes due to the roller lifter bearing failure. The cam was repaired and new lifters installed... Any way I have less than 500 mile on the cam... Before I lost the cam I had about 5000 miles on it before last year.
I would bet this failure is the result of the camshaft repair. The first thing I would do is check the hardness of the cam. Wouldn't be the first time I've heard of a repaired cam failing. Probably a moot point though since you're replacing it with a hydraulic set up.
