Old 07-30-2010, 08:16 AM
Why does anyone bother to run antifreeze type coolant at all? For what reason? The green stuff has it's problems, it is not recommended in all cases, nor is Dexcool. One must choose wisely his mix of coolant, or additives if your running straight water. What type of "savior" coolant would you choose? Are you using a special antifreeze mix to control corrosion or for freeze protection? Do you run water in the summer, change to antifreeze in the winter? Run a high pressure cap because you FEAR boil over?
One must choose his poison, green, yellow, red, whatever color of the rainbow that you like for your coolant. I see no evidence that ANY of the other coolants on the market are superior to Evans coolant. So, why not run the best? Really, WHY NOT??? WHAT is the downside here? I don't see one.
Whatever "poison" you choose, in a couple of years the additives will be depleted and the coolant should be changed or new additives added. Evans coolant doesn't need or use additives, put it in, your done.
