Old 07-30-2010, 09:16 AM
mikeforte mikeforte is offline
Smile Tko-600 .82
Hi Jason,
I agree that the TKO-600 .82 is a great fit, lighter and will work fine in most applications. The bellhousing, clutch kit (26 spline) is a bolt in with the short input installed.
As for the T-56 Magnum, it does fit many applications and can "split" the overdrive so you can have the best of both worlds....
Originally Posted by D-CEL View Post
Companies aside, I have to go with Brent's advise on the trans. A TKO is a much better fit than a T56 in this application. I cant see any reason to run a T56 in any Cobra, let alone this one that is over cammed and tall(er) geared. At the high speeds where the gear split advantage of the T56 would be useful, a Cobra has crashed into the aerodynamic wall.
The higher weight, physically bigger in every respect T56, offers little (if any) advantage and does it at a higher cost.
Don't get me wrong, the T56 is a cool trans, just not in this application.
The TKO is smaller, lighter and cheaper just a better fit in my opinion.
Jason
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
