Old 07-31-2010, 12:57 PM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
"Technical article on the Hot Rodding sites" That's where you would look for tech advise?
If you're changing ride heights when adjusting corner weights then you're doing it wrong. Ride height is set 1st, then alignment, then scaling. Ride height is maintained through out and doesn't change when scaling.
I would suggest Longacre or Intercomp for tech advise on the correct procedure.
Here: Under "Tech Articles" from Longacre's site- Scaling made simple
http://www.longacreracing.com/articles/art.asp?ARTID=1
