Thread: IM240 test
Old 08-01-2010, 04:04 AM
NASSTY NASSTY is offline
Cobra Make, Engine: RCM, 4 wheels, two doors
As I broadly understand it, NOx is mainly affected by timing.
CO and CO2 is more a fueling issue.
Mando, is your set up running closed loop? If not, unabling closed loop should fix alot of your tuning issues as the ECU will trim up your A/F ratios to 14.7:1 which is what your cats need to work properly. I assume you're using aftermarket EFI.
