Old 08-03-2010, 08:05 AM
blykins blykins is offline
Default B2 Motorsports Budget 408W Short Block Plus
I'm trying to offer some good deals with some name brand parts for those guys that like to finish the top end themselves. I know there are other builders selling kits like these for $3100-3200, but please take note of what you get with these short blocks. My stuff comes with all brand new parts....no reground crankshafts, resized 30 year old rods with press fit wrist pins, reused main and rod bolts, etc. My short blocks also come completely balanced with the harmonic balancer and flywheel. Even a Melling oil pump pump drive shaft, and a new timing cover are included.
Parts List:
*Fully machined production 351W block, magnafluxed, cleaned, bored/honed with plates, align honed, square decked. Cam bearings & freeze plugs installed, block painted to color of your choice.
*ARP main bolts
*Scat 9000 series crankshaft
*Scat forged I-beam rods
*Probe forged pistons
*Hastings rings
*Comp Cams hydraulic roller camshaft with Comp Cams lifter spider
*Clevite main and rod bearings
*Felpro rear main seal and front cover gasket
*ARP cam retainer bolts
*Ford Racing timing chain set with new cam retainer plate
*Professional Products harmonic balancer
*ARP balancer bolt
*PRW billet steel flywheel
*Melling HV oil pump and pump drive
*ARP oil pump bolts
*ARP flywheel bolts
*New fuel pump eccentric
*New timing cover
*Rotating assembly balanced
*Fully assembled with build pics and complete build sheet.
$3950
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
