Old 08-04-2010, 07:38 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Default drilling block
Don't use a 2 x 4
get a piece of thick aluminum that is long enough to bolt down with one head bolt and a hole for the tap size drill at the proper spacing for drilling out the old hole---also drill another hole the same distance and actually run the helicoil tap thru it as a guide---1 inch thich is probably enough ,,, thicker is better(more guide)
