Old 08-04-2010, 07:58 AM
blykins blykins is offline
Ross,
Quicktime's SBF bells are only compatible with 157T wheels.
JHV,
Hopefully the symptom would be that you can't bolt it up all the way. Otherwise a lot of damage could occur....if the input shaft pilot end pushes the crankshaft, you're looking at a smoked thrust bearing.
The difference between a T/L bell and TKO bell is about 3/4"....so the difference would be apparent. However, it's ALWAYS wise to check depth and to dial in the bellhousing.
Jerry,
I appreciate that. Thank you.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
