Old 08-04-2010, 08:01 AM
capteddie's Avatar
capteddie capteddie is offline
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
OK DV. So how do you want to do this?
You can have the car back around mid September or early October. Whatever works best for you and you can have the car till spring. I would suggest you have it so you can get the car up on the lift, so you can see where the finish on the lower panels is bad. Also that would let you go over the entire underside to check things out. Thats how I found the roll bar bolts and the bolts on the sway bar that don't thread completely threw.
If you want. I'll also hold off on getting the gas tank fixed, even though its out and sitting on my garage floor right now.
As I said in the other thread. I really don't want to throw another wheel barrel of cash at this car. I would like to try and make the Kirkey seat fit, along with moving all the switches off the left side of the dash. Stuff like that. I wouldn't have a problem paying for.
Balls in your court....
"the other ed"
