Old 08-04-2010, 08:55 PM
Pete Munroe Pete Munroe is offline
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default brake fluid in fuel lines...
The no-pressure gravity feed lines from the brake reservoir to the master cylinders weep brake fluid.
Wouldn't call it a LEAK, never add fluid, but the lines are wet and slippery...its not moisture.
The original lines are SAE spec 30R6KX. Three are original lines, about 7 years old and on one of the brake master cylinders about 3 years old.
Doing a lot of r&r for other odds and ends, thought I would change out the lines, but only if the new hose will not WEEP through the wall.
OK, is there a SAE spec fuel line that is less permeable to brake fluid?
I have some replacement hose, labeled SAE 30R7. One piece is labeled "fuel vapor" "not for fuel injection systems" the other SAE 30R7 and is labeled "50 PSI Fuel/Emission".
OK, I guess both new pieces meet the SAE 30R7 spec as labeled, ie: they are good to 50 psi with gas, but what SAE spec line may be more resistant to having brake fluid weep through the side?
Thanks
ERA 289 #2027
