Old 08-04-2010, 09:43 PM
Pete Munroe Pete Munroe is offline
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default thanks
Guys,
I have hard steel or steel/braid lines on all hydraulic lines that are pressurized.
The NO pressure lines from the brake reservoir are the concern.
The brake reservoir is a BMW plastic piece with three outlets to the clutch master and the front/rear masters. There is no way to run braided steel ptfe? teflon core? type lines unless I switch to the "original type" metal canisters.
Will take a look at the Pegasus catalogue. They have a lot of good stuff.
I just want a easy change of material to a rubber type hose that is less likely to weep than the 30R6KX type.
Again, there is no pressure, I just don't want the lines weeping fluid...no dripping they are just wet on the surface.
Brake fluid is pretty unique/devious ! stuff...I think it was originally developed as paint remover...
I am familiar with a red rubber type line I usually think of for air compresors.
Thanks, Pete
ERA 289 #2027
