Old 08-05-2010, 02:39 AM
cobrakiwi's Avatar
cobrakiwi cobrakiwi is offline
Cobra Make, Engine: Coombe, Shelby Block 496
Hi
Is there any oil dripping from the bell housing? The bell should have a drain hole in the center bottom. If oil is coming from the bell then your clutch may by oil soaked. Check that your slave cylinder is adjusted correctly, make sure the clutch fork has a little clearance and not pushing on the pressure plate.
