Old 08-05-2010, 01:17 PM
HPCOBRA HPCOBRA is offline
Default Custom radiator hose
I am finishing up my CR w/460. I need a custom hose setup for the lower 2" hose that reduces down into the radiator (1 3/4" ?). It is so tight near the Alt belt and steering shaft that I may choose going under the engine but tucked in behind the crossmember. This would require a custom hose setup with some tight bends. I have seen some SST ridgid radiator flex that you supposedly can bend up. Has anybody had any experience with this or anything that would work. Thanks again
