Old 08-05-2010, 04:10 PM
mkassab's Avatar
mkassab mkassab is offline
Cobra Make, Engine: Unique 427 S/C, 427ci
Mark, you're planning on buying a simple automotive relay and using that relay to provide the ground to that nice Painless solenoid, correct? .
Correct. The battery sw itself has a built in relay and not knowing it's requirements, that's why I was inserting a 30 amp relay between the Battery sw and the security system. So my inserted relay would give the ground to the battery sw relay.
Thanks for your help. I'll check out your link. Mark
Unique 427 S/C, B2 Motorsports 427ci SBF, TKO600, Jag IRS 3.73 Posi, Avon Tires.... and so much more http://www.uniquecobra.com/forums/forumdisplay.php?f=68
