Old 08-07-2010, 10:10 PM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
This gets tricky, if you lower the engine, you either need to also lower the trans or your pinion angles get goofy.
If you indeed want to do this, I would suggest figuring out exactly how much room you need, then add a margin for error.
Make friends with a local hotrod , motorcycle or truck shop. They should be able to help you weld up some custom sub mounts to accomplish your goal
