08-08-2010, 06:48 AM
Cobra Make, Engine: SPF#0760
Somewhere, this thread was about an alignment...right?
I don't know how low you made your car, but 27" to the lip of the wheelwells is the recomended ride height. (with stock tires and 15" rims) You can push these numbers to 26" with no problems but after that you need to be carefull with bottoming out the suspension on hard acceleration, bad roads etc.. Wheel clearance is another issue too. The rear tires can rub the fiberglass...What tire pressures do you run?
SPFWiringDiagrams@Comcast.net
