Old 08-08-2010, 07:42 AM
mikeforte mikeforte is offline
Smile Engine height
Hi Dugly,
From what I read below your trying to get more hood clearance. I sell a 14" x 3" tall filter assembly that is about 1/2" above the air hord of a Holley carb. This filter assembly almost covers a Holley carb it is so low.
I stock these and can post a picture from work on Monday.
Originally Posted by YerDugliness View Post
I'd like to use a high-rise Performer RPM Air Gap intake manifold and my current K&N X-Stream filter on my Cobra replica ( http://www.knfilters.com/search/prod...x?Prod=66-3150 ), but there is only about 1/8" clearance between the top of the air cleaner and the underside of the hood scoop right now with the Edelbrock Performer intake and Edelbrock carb. I guess I could use a drop-base air cleaner base, but I'd rather be able to use the stock Edelbrock base, which is only slightly raised but nicely radiused. The current base is not raised or radiused.
Does anyone make motor mounts that will lower an engine? I've thought about having new brackets welded to the frame to fit standard motor mounts, but if anyone knows of mounts that lower the engine, I'd rather try them first.
In the past I was successful in slightly lowering a 351-C that I stuffed into a Maverick by slotting the holes for the mount bolts, but I don't think that will be enough this time.
Just FYI, the current motor is an 8.2" SBF, a 1989 Mustang GT 5.0 that has been switched from EFI to carb.
The rear end is a Ford 9" mounted by a parallel 4-bar system. The bars all have adjustable ends, so the pinion angle can be adjusted rather easily if need be.
Thanks for any information you can provide or any suggestions you might have.
Cheers from Dugly
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
