Old 08-08-2010, 01:37 PM
gsharapa's Avatar
gsharapa gsharapa is offline
Kevin,
I went back and looked at the post from CSX3170 on his big FE with solid roller..........
__________________________________________________ __________________________
I'll give you the short version, engine is Shelby FE block, Blue Thunder raised port heads (it only needs 29 D. advance at peak power), MSD, Carrillo rods, Victor jr. manifold- highly modified, Ti Valves, 14.7 to 1, 1650 cfm Throttle body, seq. EFI really big roller cam, peak power 7600 peak torque 5500, headers are 2 1/8 primary 3.5 collectors. This engine has a Daley dry sump and Stefs tank and never leaks oil as long as it is running (13" of vacuum) CID = 498 with a Moldex billet crank. Engine by Kinetics in Michigan
Gary
CAV GT40
