08-08-2010, 08:57 PM
NH
The type I picture are for original type applications. The bottom one comes out of the radiator wraps around the steering and through an X memeber. If your path isn't that complicated you may be able to modify one of those or as suggested put one together from individual stainless bends. Even if you cut and fit and duct tape together and take them to your friendly local TIG welder and if he's good he'll use backing gas inside for welding. That would also make a diameter transition easy to wiggle in. Mine are 18 Ga (0.045") SS and they are priced at $175.
