Old 08-09-2010, 12:45 AM
Gav's Avatar
Gav Gav is offline
Originally Posted by hsv300 View Post
This is the email i got when i questioned the charge:
Hi Greg,
The EFI charge is a Licence to perform an ECU modification. It
is required with each separate modification ( at separate times ).
The charge for the tank was @222.73
I don't know about EFI live but this is not the case with HP Tuners software. The serial numbers of the PCM's that the programmer has applied credits to are stored in the MPVI which is a storage device in the peripheral lead. So if the same lead is used, the PCM is recognised by the MPVI and acess is allowed.
When you purchase HP Tuners you also are given 'VCM suite' which is diagnostic software that requires no credits and is read only. It does not allow access to any parameters only diagnostic information like error codes and operational data.
Powered by Cu
