Old 08-09-2010, 07:56 AM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
In regards to the fluctuating speedo... I have found on a couple cars that the inner cable is a fraction too long. It then is forced to be slightly "bent" in the casing and creates the pulsing. If you use a grinder or cut-off wheel and take just a little off, it goes away. I'd try that before installing a completely new cable. I even remedied it on one car by lossening the ring nut on the back of the speedo and it released enough tension to stop the pulsing as well. Just my.02.
WDZ
