Old 08-09-2010, 04:36 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Originally Posted by Clois Harlan View Post
I believe the motor mounts (engine and transmission) on a convertable are about 1/2" lower. But, keep in mind the issues raised in the above threads will come into play. Make sure your pinion angle is not compromised.
Clois
Thanks for this info, Clois! It may well solve my problem without necessitating adjustments to the parallel 4-bar rear suspension to re-orient the pinion angle. I do have an inclinometer somewhere, so I can make the adjustment if needed, but lowering the engine and transmission equal amounts may well negate the need for that. I have asked a friend from the GT40's forum to pull parts at the Ford dealership in which he works and see if there is indeed a difference between a sedan and convertible.
Originally Posted by Jerry Clayton View Post
You can gring off some material where the mounts fasteb to your block---since the 302 mounts are square to the world vs at an angle you can easily and safly take 1/4 inch off there--you might have to use shorter bolts so as to not bottom out in the holes
Thanks for the suggestion, Jerry....this was the route I used when I lowered the 351-C in that Maverick.
I've done the math and according to Edelbrock's pad height formula I need 0.775" additional clearance to switch out the intake manifolds only. If I can get 0.5" from the convertible motor mounts and 0.25" from grinding some material off the motor mounts, perhaps there is enough clearance to make the switch....I can grind off a new set of motor mounts and put them on the Cobra without removing anything and check the new clearance dimension with some modeling clay before I even need to order the manifold.
Just curious, I do have a Holley 600CFM vacuum secondary carb....does anyone know off the top of their head whether the Holley carb is "taller" than the Edelbrock? If the Holley carb is "shorter", I could gain additional clearance by switching out the carb...I just hate to do so if I don't need to absolutely do so, the engine runs so strong with the Edelbrock, no bogging, no problems of any kind.
Originally Posted by mikeforte View Post
Hi Dugly,
From what I read below your trying to get more hood clearance. I sell a 14" x 3" tall filter assembly that is about 1/2" above the air hord of a Holley carb. This filter assembly almost covers a Holley carb it is so low.
I stock these and can post a picture from work on Monday.
Thank you, Mike....do you also stock a 9" dropped filter model? Actually, all I would need would be the dropped base plate as I already have the 9"X3" K&N filter and the X-Stream filter top. I have resisted using a dropped base b/c I figure it will result in increased restriction, requiring the air to make a sudden change of direction, but if all else fails I think I might well be able to manage with the additional filter area of the K&N's X-Stream filter top. The current filter really fills out the area under the hood scoop, so I'm not sure how much flow I can count on from the X-Stream filter top with it being so close to the underside of the hood scoop.
I'll have to check out what effect the 3/4" drop has on the headers....that may be a problem or it may not. I can shim the "rear mount" where the back of the headers attach to the frame easily enough.
Thanks for the suggestions and information, all....anyone else have any ideas?
Cheers from Dugly !!
YD,E./PNB
No names were changed to protect the innocent!
