Old 08-10-2010, 01:39 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Like the idea of getting a small amount milled from the carb pad! If the motor mounts are really worth .5" and grinding another .25", then all I need is .025"....that's practically NOTHING, and might be possible with the aircleaner/carb gaskets.
Keep in mind that the .775" is just what I need to be able to mount the Air Gap manifold with the current Edelbrock carb and X-Stream filter, but not using the raised/radiused base that came with the X-Stream, using a different flat/not radiused base. I might be able to get that K&N air cleaner base in with all these hints....
Thanks, and keep 'em coming, guys!
[Edit--getting closer! Current filter is 2.75" tall, and I found a 9" diameter K&N filter in a 2" height...not listed on the X-Stream page, but when I did a search by dimension I found this:
http://www.knfilters.com/search/prod...px?Prod=E-3527
So, things are looking up!]
Cheers from Dugly
YD,E./PNB
No names were changed to protect the innocent!
Last edited by YerDugliness; 08-19-2010 at 07:52 PM.. Reason: Add new filter I found!
