Thread: Check this out!
Old 08-11-2010, 12:43 AM
Rob. Smith Rob. Smith is offline
That's scary with the roll cage mounts and the comments on fitting them...cut a hole in the floor to lower the cage to weld it then weld a thicker plate over the hole....In all the books I've read the roll bar should be mounted on a chassis member or sandwich plated to a structural member ie:- the sill or pillar frames...It looks like this particular roll bar was installed so they didn't damage any interior trim. How did they get out ? through the boot ?
