  #82 (permalink)
Old 08-11-2010, 08:34 AM
Barry_R Barry_R is offline
Originally Posted by madmaxx View Post
Your oil pressure connection is tied into the main oil galley. It does not matter if you are running 10wt at 3 psig or 80 wt at 50 psig, the flow rate will be identicle on a positive displacemetnt gear driven pump at a give rpm. Difference between standard volume 3 gpm and high volume is 3.25 gpm. so high volume is 10% more. The gauge tap is before the oil cooler, filter, lines not after. All factory set oil pump rv are set to releive at 60 psig, if you are below 60 psig your flow is identicle regardless of pressure. By the way your oil filter has a internal bypass set at 10-12 psig differential unless you have a high performance FL-1HP and then it is set 18-20 psig differential. If you have 90 psig you internal bypass is opening on your filter and you are bypassing you oil filter.
Will you please stop spouting facts based on physics. You're gonna get some guys upset. Everybody KNOWS you need 8 million pounds of oil pressure or your car will spontaniously combust..
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
