  #26 (permalink)
Old 08-11-2010, 05:34 PM
madmaxx madmaxx is offline
Make no doubt hydraulic lifters can bounce on the backside also with an agressive cam profile. Anything above 5.5K rpm you are risk. It is usually seen as valve float but if the hydraulic lifter is set near zero lash then you may not experience valve float. Some like Keith Craft make high rev lifters which add about 500 rpm over traditional hydraulic lifters.
