Old 08-12-2010, 06:49 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Skuzzy View Post
I was referencing a post that stated the pressures are not even between the mains. I still do not see how that is possible. I do not question the validity. I am just ignorant to how it can occur without some type of blockage in the oil feeds or some mains that are so open they all the volume of oil coming at them to bleed right on out without any back pressure at all.
It's actually pretty easy to understand once you see how the oiling system was designed, that is, main bearing #1 has a direct feed from the main oil gallery, but the for the oil to get to main bearings 2-5, the oil must first pass around the cam bearing journal directly above it.
Actually, I have a picture of it, but decided not to post it.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
