Old 08-13-2010, 07:48 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by Skuzzy View Post
No, no, no. That is a parallel connection. For two 6V batteries, you have to connect + (on battery 1) to - (on battery 2) then connect the charger to the - (on battery 1) and the + (on battery 2).
That is, if you are charging them with a 12V charger.
You do not want to charge a single 6V battery with a 12V charger.
Also note, a fully charged automotive battery contains 2.5V per cell. If you measure the voltage on a fully charged battery not connected to the electrical system, it should measure 15V.
Oh, I see what you read. I saw it perfectly but stated it badly. I should have said "just connect the +[of the charger] to the + of the first battery and the -[of the charger] to the - of the second battery.
Furthermore, the +'s are to the primary hot lead and the -'s are to the frame ground lead since "battery 1" or "first battery" are also ambiguous.
English is such a crappy language for technical specifications.
