Old 08-13-2010, 07:59 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by wrench87 View Post
i called comp with my serial number for the cam they told me to only run a bronze gear, i dont want to ruin a 13k engine. what gear is everybody using on the comp cams keith craft cams?.
this gear will be the correct one for the FE and a MSD distributor. MSD's shaft size is larger than the factory FE distributor. listen to Barry's advise and spin the gear 90 deg from the existing hole , press on, and then redrill thru the gear and the shaft an all new hole. the new gear will come with a new roll pin. lube with the supplied lube on install. note debur the old hole of shrapnel before pressing on it will make it easier. and use some oil for lubricating before press fit.
http://www.summitracing.com/parts/MSD-8581/
Fred B
