Old 08-13-2010, 09:30 PM
timsullivan's Avatar
timsullivan timsullivan is offline
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Milan: Late model SPF's have the reservoir located in front of the cross member (located in front of the engine). It is located directly behind the left side radiator fan motor, on the left side of the engine compartment, secured to the inner fender well. If you look you'll probably find the mounting bracket there. Many times installers remove the reservoir tank because it sometimes interferes with the front oil cooler oil hose routing or they think people will rarely use the windshield washer system to begin with. The washer pump motor is mounted to the bottom of the reservoir.
