Thread: Engine Carnage
Old 08-14-2010, 04:04 PM
Outwest34au's Avatar
Outwest34au Outwest34au is offline
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
Lash caps are also used/ called rotators or slow rotators. The valve is normally pressed down in this case just off the centre line and the cap acts as a thrust washer allowing the valve to rotate a small bit on each open/ close cycle. This is to dissipate heat evenly around the valve seat and wear evenly too. Some bigger engines have actual thrust bearings with balls.
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
