Old 08-15-2010, 12:22 PM
Dazecars Dazecars is offline
Originally Posted by cobrarkc View Post
This is not true, the hub shafts are a different diameter so you either have to put a bushing in the wishbone or put different bearings in the hub with a shim around the bearing and a spacer under it to make it work. I just completed this project.
You can use the stock brakes but I upgraded to 12.19" Wilwood That is bracket I made to mount the Wilwoodcaliper in the middle picture along with the bearing, shim and spacer.
Good point, I was aware of the shaft size difference. More than anything, I was thinking of it as another option to have a solid mount for an upper watts with out having to drill in to the hubs, and wondered what others thought.
