Old 08-15-2010, 03:47 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
When you moved the brass tubing, you did so gently correct?
When you finished retightning the sensor end, and went for a ride, was the brass tube and its steel protective coil touching a spark plug wire or positioned so that a spark could jump to it from a wire on the cap?
That would kill it quickly...
You loose the gas inside the tube...a microscopic hole in the tube from the spark(s)
DId you get air air out of the connection?
SPFWiringDiagrams@Comcast.net
