Thread: Half Shafts
Old 08-15-2010, 07:59 PM
Bartruff1's Avatar
Bartruff1 Bartruff1 is offline
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Smile
Originally Posted by madmaxx View Post
Bartruff1,
Inside the rubber boots is grease. Grease is made of soap and oil, Soap is used to hold the oil in place. If you are seeing a drip of oil, which given enough time will make a 3" diameter discoloration on cast aluminium you may have no issues. If your boots are not split, forget about it. Beleive it or not 80% of the grease in cv joint never sees service, how would it nothing pumps it in there. The grease is spun around any by centrifugal force the oil gets seperated from the soap and by capilarry action finds it way out.
As far as the rear end leaking there should be a drop or two every now and then, it keeps the lip seal lubricated. If you aint getting drops on your driveway every single time you drive it you do not have a problem.
If you do take it somewhere make sure they dont try to take you for a ride.
By the way buy GLD hold through september and sell, statistics shows it goes up 5-7% in September every year since 1993.
No kidding !!! You mean there may be no problem ?? The SOB is on the upper bunk and dripped on the Z06...I have never seen any on the garage floor...You don't think they would take me for a "ride" do you ?? I have been buying that white lithium grease and it really reduces the pain...the dealer here has two kids in college thanks to SPF 2811, he has a picture of it on his desk. A gold spider.. never have done that...I am heavy into Annaly Cap Mgt (NLY)... commercial real estate in selected high end markets...pays 16% with a PE of 9... I will take the car to my most trusted mechanic and let you know...thanks for your advice...
