Thread: Half Shafts
Old 08-15-2010, 08:21 PM
madmaxx madmaxx is offline
That almost sounds like it may have been overfilled, pull the plug with the car level and it should be at the bottom of the hole. Trust me when you are driving it is a shower of oil in there. I have not seen but imagine there is a breather on top to vent any pressure. make sure it is not plugged. If you check the level and it is fine dont worry, if you check and it is low add some and watch for drops. I would hate to get into the rearend.
Originally Posted by Zoom This View Post
I just got back from a 3k mile road trip with many high speed runs - 120+ mph - across Montana and Wyoming. I bring this up because I have found three quarter coin sized puddles of fluid that looks like it may have come from the pinion seal(?). Thinking maybe the pressure build in the ring and pinion housing at high speed may have caused this leaking that showed up on my garage floor when I got home. A short trip across the Island and back showed no continued leaking from the rear end area. Should I not worry about this??
