Thread: Half Shafts
Old 08-16-2010, 08:34 AM
Bartruff1's Avatar
Bartruff1 Bartruff1 is offline
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Originally Posted by madmaxx View Post
You old farts have to remember when all cars leaked, dont believe me look at the freeways the center is darker than where the tires ride, why? because cars drip oil. Why are roads so slippery when it first rains, because all the oil goes to the top of the water. We are used to our GM's, Fords, Lexus, hyndai's going 100K miles and never leaking a drop, well these are not GM's and Fords. A drop or even a couple drops here and there will hurt nothing, sheet I used to park a car on the street the transmision leaked so bad, who cares dump some fluid in it. Now if it is dripping on another car that is a problem. If your lilft is like mine pick up some drip pans at Autozone, big tin ones, they fit perfectly between my runways.
Also remeber when oil gets hot it really thins out so any little gap sufficient for surfact tension and it will bleed. Its August and we are going to see some leaks.
Its so miserably hot in Houston 100F at 70% humidity I did even start it this weekend. By the way the MGD 64 aint worth a crap either. I had to dring 24 of them to get the same buzz as 12 miller lights. Hell you would drown before you could get drunk on the crap in this heat.
Patrick... your words are so...so reasuring...god bless Max and keep him safe... I think I will strap on a new depends and take that bad boy for a spin...as for your weather.... get a corvette...
