Thread: Engine Carnage
Old 08-16-2010, 11:05 AM
TButtrick's Avatar
TButtrick TButtrick is offline
You might also check the spring seat pressure at installed valve and max lift height. Any good engine builder will have the ability to measure the pressure with a force gauge at installed and max lift height for your valve geometry. When they test for max seat pressure, they should also check for bind (min space between coil turns at max compressed spring height)
