Old 08-16-2010, 03:10 PM
Bobcat Bobcat is offline
Kramer ... other than unbolting/bolting the seat hold down nuts , you really don`t need to do anything from underneath the car . What Bob came up with is locating the bracket over the chassis member that is under the floor from the top . Pull up the carpet and locate the holes per his drawing . You then drill and put the nut serts in , which are placed in the chassis member itself and the bracket rests on the floor . I put the carpet back , bolted the bracket down and then cut away the carpet so the bracket would be on the bare floor . Keep in mind that you will probably have to bend the belt mounting hardware at either a 45 or 90 degree angle to clear the seat bottom on bumps/road dips , however , this can depend on where you have your seat adjusted ( adjustable seat ) .
Really works well .
Bob
