Old 08-17-2010, 08:33 PM
cman46's Avatar
cman46 cman46 is offline
Cobra Make, Engine: Shell Valley, 302 with NOS
Larry, you are correct the site does state tire ratings of V, W, Y or Z. The tech sheet reads tire speed rating must be at or above manufacture OE specified speed rating for that vehicle. Considering the kit and typical 15's frankly I figured it would get through tech as it has in the past. It did not and certainly ol Col does take responsibility for that issue. The main purpose of the post is to alert others not to make the same mistake. If one is considering going to the event, again, check the cancellation policy, time requirements and comply one way or the other with the tire requirements. In addition if there are other issues prohibiting the vehicle passing, keep in mind if cancellation is not submitted 30 days prior to the event you are penalized 50% of registration which can only be transferred to another event. Prior to thirty days 100% is transferred to another event. If you cancel 15 days prior no credit is issued. There are several terms for that situation. Col
Under Promise and Over Deliver!
