Thread: Hot air leak
Old 08-17-2010, 10:30 PM
tin-man's Avatar
tin-man tin-man is offline
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by Skully View Post
Thanks for all of the info TinMan.
The problem is the void gets me hot , just want to fill the void. Where in Sun City West do you live? We belong to Briarwood CC, at 135th and Meeker. Oh , getting back to the void, will the foam work, or is that to close to the heat from the engine. The temp on the can says nothing over 240*, the heat coming off the engine is more than that. Do they make a foam designed for more heat?
Skully, Corte Bella, four weeks outa the year, the rest of the time in China, regarding the foam, my understanding is there is a foam available that is used on the shuttle rentry vehicle and the temperatures get red hot depending on the angle of the re-entry. Not sure of the actual temperatures but hot nonetheless, sometimes causing a melt down. I understand Dann55 may work in the aerospace industry and may have knowledge on this, perhaps he may want to weigh in on this topic? Danr55? tin-man
Be well, drive fast, live long
