Old 08-18-2010, 06:14 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by cobrarkc View Post
Doug
What exactly do you need for the emergency brake? Do you have the small calipers and brass fork? I have a complete setup I just took out of my car. I also have the cable setup for Contemporary as per the instruction manual. It has a few broken strands on the cable but should work fine. I also have an FE goosneck breather for the intake unless you are going to run PVC to your breathers.
Rich Carlisle
Hi, Rich. I have an emergency brake handle boot, that's about it. I need to source everything else. The rear calipers are Jag Series II Girlings. I need the handle, the cable and any sort of hardware that connects to the steel e-brake caliper levers in the back. If you have something that'll work that would be wonderful. Thanks!
