Old 08-19-2010, 06:57 AM
jhv48 jhv48 is offline
If ice on the manifold cured the problem, then vapor lock is your problem.
You can get the phenolic spacer from Summit Racing. Don't use wood or metal as a spacer. Wood can swell from the fuel and metal doesn't insulate as well as the plastic does.
Also, try running with the fans on when travelling slow during warm days. Air circulation can be a problem at slow speeds.
Jim
