Originally Posted by Cashburn
You cannot have a drop base that is smaller than the overall carb dimensions.
....exactly what I was told:
Originally Posted by mikeforte
Hi Dugly,
The drop based 14" air filter assembly is the smallest it can be. The size of a Holley dual feed carb requires a 14" filter assembly for the drop based filter to fit over the carb.
In Bernica's case, the limiting factor might well be what will fit within the turkey pan rather than what will fit between the inner walls of the hood scoop...just figured that one out
Cheers from Dugly
