Old 08-20-2010, 08:10 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Have you pulled the pan on the motor? I dont how they balanced the crank but if they added weight could one of the weights have come off? At this point I think you have gone past the point of the clutch and all that. I think pull the pan and give a good visual inspection. Make sure there aint nothing floating around in the pan thats supposed to be attached to the crank.
just for S%*ts and giggles...do a compression test on all 8 cyls if its not too much trouble just to make sure.
Just some thoughts.
" If it wont break em loose in 3rd gear, it aint enough power "
