Old 01-10-2002, 01:42 AM
427Aggie 427Aggie is offline
Cobra Make, Engine: ERA #122 (Sold) : Ford GT #484 Heritage Edition; 2008 GT500 Red/Black
What type of fuel pump are you using...the spf use electric right? If its mechanical and you haven't run it before pumping the gas pedal won't do it you will probably need starting fluid. First thing is to check from the basics up....
Look in the carb and pull the throttle linkage do you get a squirt?
Pull the coil to distributor wire and see if you get spark?
Pull a distributor to plug wire and see if you get spark?
If you have the above it should start...I would do that before pulling the valve covers and getting into the rockers....
Matt
